Brett Brown
Roof Tool Outlines
Don't know if this has been brought up before but why,why,why does 2 roof planes with the same pitch and outline line type are totally different? Can't be because ones a single roof plane? Same in AC 24
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
11 Replies 11
Seems to me there is a problem with multi-plane roofs not showing the Outline (Uncut) line type properly when the entire roof is above the Floor Plan Cutting Plane.
The rest all seem to be showing as you would expect.
PVBergkrantz
Similar to my post here, check it out and see if it gives any clarity.
https://community.Graphisoft.com/t5/Design-forum/Roof-shown-as-overhead-with-outline-selected/td-p/3...
| AC 29 Int | Win11 | i7-7800X | 32 GB | GeForce RTX 2060 6GB |
