ā2022-01-27 07:10 PM
What is causing this issue? I use the connect tool to trim walls to roofs and occasionally it creates a void in the roof plane where the wall intersections. I am attaching an image
ā2022-01-31 02:37 AM
Is your wall building material stronger then the roof building material?
If so the wall will cut through the roof.
For this reason I still prefer to use Solid Element Operations for walls and roofs.
ā2022-01-31 10:34 PM
Could be a Layer Intersection Group problem. See if this GS Help Section gives you a solution.
Use Layers to Prevent Intersections | User Guide Page | GRAPHISOFT Help Center
| Archicad 4.5 - 29
| HP Z840 | 2Ć E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
ā2022-11-05 01:25 AM
Your answer doesn't make sense, could you add more detail?
