Trim function issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-09-25 05:26 PM
Wondering if anyone can advise. When using the trim tool between the roof plane and wall, I end up with the wall showing on the surface plane of the outer roof. Attached image shows the issue. Why would this occur?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-25 08:00 PM
This happens because the building material of the wall is a higher priority than that of the roof. You need to either change the material of the roof to one that has a higher priority than the wall or open the Building Material settings from the Attribute Manager and increase the priority so that it is higher than the material used for the wall.
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-25 08:00 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-09-25 08:03 PM
Thanks for that. Appreciated.
