Steve Jepson
SECTION SETTINGS
What setting makes it so the Story Elevation Text is not cutt off like this ?
I can only make the font so small and still read it.
DGSketcher
Legend
Looks like you are displaying a second line of text with the upper dimension. Have a look at the settings to see if there is blank reference displaying that you can turn off.
Steve Jepson
It seems that the Story Name Text or Story Index Text is blocking out the space it would be in if it were on. The None setting should be an Off setting so it can't do that.
The work-around is to mode the Story Name Placement to On The Line which will automatically put the Story Elevation Text under the line where is wil not be blocked out by the Story Index Text or Story Name Text, which ever of these is blocking out the place where the Stroy Elevation Text is.
I would show the Story Name Text and perhaps the Stroy Index Text but wha I am calling them make no sence relative to the Elevaiton or Section views so I am just showing the Elevation Text.
