Niranjan Das Sharma
SEO edited terrain documentation
I am not able get the level markers return the levels of terrain modified by SEO nor I can see the newly generated ridge lines. How do i see and how do i put the new level markings?
Thank you.
Operating system used: Mac Apple Silicon macOS Sequoia
4 Replies 4
SEO has no effect to elements in plan.
And in 3D, you are not actually altering the actual meshes, it is just a cutting shape concealing part of it from view.
The only way to amend the contour lines (and hence be able to add levels) is to actually edit the levels of the mesh itself.
Add new contours to represent the cut and fill banking and then adjust the levels of those contours and needed.
Lingwisyer
Guru
Maybe you could look into using a 3D Document, or at lease overlaying a 3D Document of your site?
Though, what are you using as your SEO operator? If you are just using a Top Surface mesh, could you just DIM that instead?
Niranjan Das Sharma
Ok Got it. I will try
Niranjan Das Sharma
I was using morphs for SEO operations. Didnt think of top surface mesh as operator.  will try that. Thank you !
