Tazo Kikoria
SVG or PNG Icons for all ARCHICAD Commands
Hi There. I want to use OSU Keyboard for better performance while working. See photo:
With this keyboard you can assign any ARCHICAD command to these keys. For example, I was thinking about this type of order:
• Save
• Cut
• Copy
• Paste
• Drag a Copy
• Rotate a Copy
• Mirror a Copy
• Split
• Intersect
So I wanted to put the stickers on those keys. I was looking for ARCHICAD icons of these commands:
Tazo_1-1724218688182.pngTazo_2-1724218717205.pngTazo_3-1724218738650.png and so on.
I saw a post where some ARCHICAD tools were downloadable from API account:
https://archicadapi.graphisoft.com/Archicad-gui-icon-style-guide
But here are only main working tools. Is there a same type of link to all ARCHICAD commands?
Thanks.
1 Solution
vistasp
Years ago, I had experimented with making an Archicad toolbox out of a cheap number pad. As Barry has suggested above, I'd taken screenshots of the icons but then traced over them in Inkscape to give me the .svg images I needed.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Go to post
5 Replies 5
Just do a screen capture of the pet palette or tool bars?
Then a bit of editing/resizing and you can print it on your stickers.
Tazo Kikoria
I wanted them to be transparent. That's why I was looking for SVG or PNG.
vistasp
= v i s t a s p =
bT Square Peg
If you have any image editing software, you could create an alpha channel to leave just the image you want.
Lingwisyer
Guru
Could you not just use the Trace Bitmap tool in Inkscape? Or Image Trace in Illustrator?
