SOLVED!
SYMBOLIC FILL does not show properly. Need Help
Hi all,
In a current file I am working on, all the symbolic fills do not show properly on the drawing. I've checked inside the FILL setting and they still appear as designed.
Attached is one symbolic fill I've tested. As you can see I've created a Flooring Tiles of 300 x 600. But it does not show as 300x600 on any drawings.
I've checked the Fill Override Option, it is NO Override.
I tried on a fresh file then it works nicely.
Am I missing something somewhere?
Thank you
1 ACCEPTED SOLUTION
Solution
I am guessing you have managed to switch of the 'On Screen Display Option' for "Vectorial Hatching'.
5 REPLIES 5
Steve Jepson
Edit Vectorial Pattern ?
Thanks for your reply.
I've tried what you've shown before as well. It shows fine in the EDIT FILL but not in drawings. Please see attached. The fill behind in the picture is actually the fill in the drawing.
Again, in a fresh file, it works fine.
Still I don't know how to fix. Any help?
Thank you
Solution
Hi Barry,
Thanks alot for your guess. It's right.
Cheers
Steve Jepson
for others who may have the same issue
