Scale in view map and layout
Llian
My drawing of a building in view map is set to 1/4" scale.
My elevations of the different bathroom types are drawn in the worksheet to scale 1/2".
In my layout sheet, I bring in the individual bathroom plans from view map and change the scale to 1/2" to match with the elevations.
I am noticing the symbol from the view map doesn't scale down to 1/2". Please see the M5 label in plan and elevation.
Is there a setting?
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
1 REPLY 1
David Maudlin
This is the problem. Create the plan at the scale it will be output. Text and other notations are sized according to scale (they are in paper dimensions, not model dimensions), so they are getting resized if the original scale of the drawing is changed. If the plan will also be used at 1/4" scale for other Views, create a new View at 1/2" scale for the bathroom plan.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
