Scale issues with publisher.
the estimator pointed out that a set of drawings were not to scale.. so i assumed it had been scanned and or run through the copier a few times and caused it to be out of scale.. so i did some tests and the copier is exact and not altering the scales.. so i print out a new copy direct from AC12 and its to scale.. so i test the PDF out of publisher.. published a set to PDF, then printed the PDF and its out... im talking 10meters is measuring up as 9.6m on plan at 1:100.. which is quite significant..
is this a know/common problem?? can it be fixed?? as everything we do iv VIA the PDF's out of AC12
cheers
Gene
3 Replies 3
never mind.. fixed it
Think this has been around before, and below is probably how you solved it.
PDFs in AC are published to the paper size you set them at, say A1, which includes margins, as though it was the piece of paper. So if you then go to print the PDF and say fit to paper, it will only print at 96%, as it is printing the A1 PDF inside your printers default margins. You have to tell the printer you do not want any page scaling for it to be to correct scale.
This works fine in PDF readers if you are printing A1 to A1 or A3 to A3, but if you want to print an A1 at exactly 50% to A3 to maintain scale, you can't with some readers. You can't get 50% reduction in Acrobat Reader for some reason, and so we use Foxit.
Ian C
exactly it.. i had to hit the "do not scale" button in my printer settings when printing the PDF to teh printer, happy days
cheers
