Hi all,
TL; DR: I have been having a problem with some schedules where items go missing, and/or the row heights change in size when I update the drawings ( either updating the full set or individual drawings/schedules.)
The scheduled items go missing (Sometimes all of them other times only some items ) and/or the row height gets messed up. It doesn't happen always therefore I can’t recreate it every time after it happens to try to figure out what the problem is. One thing I have identified as a common denominator on all the projects where it happens is projects/files where I'm using various renovation filters. The Renovation filter option in the view settings for these schedules is set to "Show All".
Example 1: ( see screenshots below)When I Update the whole set so that I can publish afterward; The Floor Plan Notes (schedule) in my Layout will only show the header and all the entries are missing but for some reason the door/window schedules on the same layout update fine. If I open the view of the Floor Plan Notes schedule, and update, most of the time it goes back to normal on the layout, other times it takes multiple attempts. Having to comb through the set to verify all my schedules are showing up correctly, and manually update the individual schedules that got messed up each time is really annoying, prone to human error, and not very BIMinimalistic; especially since sometimes it doesn’t happen so I think the problem has been solved; I update, publish, send the set, and end up looking like a fool when stuff is missing. ,
The properties that I'm scheduling in these examples are taken from a CONTRABIM keynotes video
Example 2: ( See video )
In this example, I have a schedule that is scheduling items on different renovation filters. In the video; When I update the drawing/schedule you can see how upon completion some of the items go missing. In this case, all of the Demo items go missing except for item D16 that happens to be on a locked layer. I then Open the source view to go into my schedule, and I find all the items there, but the row size gets messed up, I then proceed to press the "Resize rows to fit content" button to fix the size, go back into the layout, update, and things go missing again. I re-did the previous steps, and it fixed itself on the second try, but sometimes it takes more attempts of poking around each of the schedules in the project to get it to work and it's very frustrating.
Any help is highly appreciated!
macOS 26 (Latest Build) - Archicad 29 (Latest Build)
