Secion/elevation marker text need to be connected to sheet name in which the section is located.
Hi everyone
I want to connect the text in the marker to the name of a sheet in which the drawing is existing so if I change the location of a drawing (from CD-2 to CD-3) the text marker change automatically. Is their any way to do that?
Please see the attached PDF for more information.
Eduardo Rolon
Yes. Look for the "Layout Id" setting
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
AC27 US/INT -> AC08
another Moderator
That worked... Thank you very much for your help.
