Secion/elevation marker text need to be connected to sheet name in which the section is located.
Hi everyone
I want to connect the text in the marker to the name of a sheet in which the drawing is existing so if I change the location of a drawing (from CD-2 to CD-3) the text marker change automatically. Is their any way to do that?
Please see the attached PDF for more information.
1 Solution
Eduardo Rolon
Yes. Look for the "Layout Id" setting
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
2 Replies 2
Eduardo Rolon
AC29 US/INT -> AC08
That worked... Thank you very much for your help.
