rob2218
Section Part Marker and Section Marker Rotations.....locked into showing the information certain way
So..I understand that you read drawing annotation from head on and from the right as though you tilt your head to the left so you can 'always' read the text rotated to the right...but how can you overwrite the Section Marker Part and the Section Marker to allow me to 'rotate' the markers so I can have the head of the marker on top and the tail on the bottom?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
4 Replies 4
David Maudlin
rob2218:
If it is the Section Part Marker_NCS 23, then Section settings > Marker Symbol and Text > Marker Geometry, Appearance > Flip Marker.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
rob2218
I'm using AC22....is it the same parameter?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
David wrote:
rob2218:
David
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
in AC22....it's located slightly differently than in AC23.
Go figure. GS...always switching and hiding where those darn "check boxes" and "functionalities" are.
thanks.
i>u
Edgewater, FL!
SOFTWARE VERSION:
