fuzzytnth3
Schedule - Exported PDF is red colour?
Published a Schedule as a PDF and the resulting PDF everything is a red colour and has dotted lines. Doesn't seem to be anything to do with Graphic Overrides or Renovation settings.
Any idea what I have done wrong?
When I export it as an Excel spreadsheet it is fine but I need a PDF so the Schedule can't be tampered with
Using AC25 5005 UKI FULL
3 Replies 3
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you for your question and I am very sorry about the issue!
Unfortunately, I cannot replicate this issue, and since there was no report about such behavior, I am wondering what was the workflow you use to have the PDF generated? Did you print the schedule as PDF (File > Print, then choose Save as PDF), or place the schedule on a layout to publish to PDF format?
Looking forward to hearing from you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
fuzzytnth3
I am using a Publisher set that uses Views saved from the Schedule window.
The first time I published a Schedule it worked fine. The second time I published it, a few days later it made a PDF that I posted a screenshot of.
I will try remaking the Schedule and Publisher set and see if it still misbehaves. I will get back to you with progress if any.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you for your help! Let me know if you can replicate the issue somehow. Even if this is file-specific only, it would be very important to have a step-to-reproduce in order to get to the root of the issue!
Let me know if there is any news about this!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
