2020-02-2111:19 AM - last edited on 2023-05-1903:28 PM by Gordana Radonic
2020-02-2111:19 AM
Published a Schedule as a PDF and the resulting PDF everything is a red colour and has dotted lines. Doesn't seem to be anything to do with Graphic Overrides or Renovation settings.
Any idea what I have done wrong?
When I export it as an Excel spreadsheet it is fine but I need a PDF so the Schedule can't be tampered with
AC versions 3.41 to 25 (UKI Full 5005). Using AC25 5005 UKI FULL Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Thank you for your question and I am very sorry about the issue!
Unfortunately, I cannot replicate this issue, and since there was no report about such behavior, I am wondering what was the workflow you use to have the PDF generated? Did you print the schedule as PDF (File > Print, then choose Save as PDF), or place the schedule on a layout to publish to PDF format?
Thank you for your help! Let me know if you can replicate the issue somehow. Even if this is file-specific only, it would be very important to have a step-to-reproduce in order to get to the root of the issue!
