We value your input!
Sections Appear in Elevation
Is it possible for a section marker drawn in plan to display in elevation? Until now, I have just been drawing a linked marker in the elevation and then moving it to the correct location to match the actual section in plan, but it would be great if it worked similar to grid lines, which will show in both plan and elevation/section. Thanks
1 REPLY 1
No sections and elevations don't show where other sections are cut.
The way you have done it with a linked section marker is probably the best way as it will actually link to the section you want rather than being just a plain text symbol.
