Polar Bear
Selection with space bar
Hello All,
Here a very basic question.
Suppose i am starting a project with a dwg 2d file as a base.
I want to make a slab on top of the slab drawn on the 2D.  When i press the space bar, the line getting selected aren't necessarily the polygon representing the slab of the 2D.  It is rather random. Is there a way to vary the selection of space bar selection?
Ambiquous and somehow hard to articulate.  But getting there 🙂
Thanks!
Archicad 25 - 5010
Macbook pro 13" /Big sur 11.4 + External 4K 27"
1 Solution
If the DWG is just lines, then the magic wand will just try to find connecting lines.
When three or more lines connect at one end point, the magic wand will get confused and have no idea which line you want to follow.
You are best to manually plot the points for you slab.
If the DWG has fills, the magic wand should be able to follow those if you click on the fill perimeter.
Go to post
3 Replies 3
DGSketcher
Legend
Assuming you don't need the 2d linework I would place the DWG on a worksheet. You can then work on your normal layers using the worksheet as a trace reference, which you can turn on/off. I think it is rare to get a space bar selection to select the right areas for a slab in a DWG, it's more reliable to drag the slab over the trace and zoom in to make sure you connect to the required corners.
Steve Jepson
and it can also help sometimes to Unify/Consolidate the .dwg lines/splines/arcs/polylines.... before you use the magic wand.  Edit - Reshape-Unify...
