Thanks for the info Henrybs14.
That was one of the ideas I had been thinking about. Sadly one cannot add annotations an dimensions to a 3D view, and that is essential to what we are trying to do.
That said, we have just tried another approach: using a Graphic Override in which Image Fills substitute the Vectorial Fills that are used in elevations. For this we defined image fills that hold the same texture image as defined in Surfaces. As you can see in the attached images, this works great!
But it doesn't. It just falls short as apparently the override 'obscures' the shadows.
Does anybody know why?!
I've also tried creating a 3D Document from a non perspectieve 3D view. But with that I can't display the textures of the surfaces.
Enhancement request for Graphisoft!!
Add a few the options to Elevation/Section settings.
For Model Display / Fill Cut/Uncut Surfaces With -> "
Own surface Textured" with Shaded and Non-Shaded.
This would greatly enhance the abilities to generate textured 2D-views.
Johan
Johan Stinckens
BIM Modeller at Atrium Architecten
Archicad user since April 2014 (v17 - v29) - CC iRT i9-12900 - 64 GB / Nvidia Geforce RTX 3080 - Windows 11 Pro 64
Other than that it's hiking, camping, climbing.
