rob2218
Simple Dimensioning Question (remove of intermediate dim?)
here's a simple AC16 question.
I have a string of dimensions. they are not "static".
I want to remove "ONE" dim in the middle of my 5 dimension tags....how do I remove ONE dim without having to re-dim all parts?
I've tried the 'hatchet'.
I've tried the various dim settings on the dialogue box.
....what else am i missing?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
4 Replies 4
As I recall, select the node at the center of the segment and hit "delete".
rob2218
....BINGO!
though...the thing a user needs to keep in mind is...the "NODE" in the center of the dimension IS NOT VISIBLE. there is no "dot" or node per say....you simply have to hover the arrow in the middle of the dim string to be remove, click it...THEN hit delete.
thank you Matthew!
i>u
Edgewater, FL!
SOFTWARE VERSION:
rocorona
Or, if you don't want a gap in the chain, select the left or right node and delete it, to merge two dimension units.
Dimensions have really A LOT or manipulation techniques.
The manual covers them all in a magnificent way (see: "Editing a Dimension Chain").
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
rob2218
thank you sir....I will look them up.
i>u
Edgewater, FL!
SOFTWARE VERSION:
