Mats_Knutsson
Mentor
Smart pdf marker links - how does it work?
Example: I have a plan of a building with ten rooms. Each room has a room drawing.
I have detail markers on the plan as well as section and elevations.
When I export a combined pdf the markers work as links in the generated pdf much like BIMx internal links. I can click a detal from the plan and the corresponding detail drawing will open.
I don't know how this works from a technical point of view. Reason for this question is that I want to find a way to get this link behaviour with text in zone stamps.
In the zone stamp I have added the corresponding room drawing number but since the zone stamp is not a marker there is no link.
Is possible to solve this in some way?
/Mats
AC 25 SWE Full
5 Replies 5
Mats,
I think that the bookmark processing to create the link only works within markers, to do what you want I think the PDF export tool would need to be rewritten to add the functionality
Scott
Lingwisyer
Guru
I would assume that you would need to rewrite the Zone stamp/tool too in order to link it to other drawings as I would assume the exporter is picking up these drawing references.
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
Mats_Knutsson
Mentor
Ling.
Guess so. Gah. ArchiCAD needs this.
AC 25 SWE Full
Erwin Edel
What sort of view is the 'room drawing'? You could place a linked marker instead of adding the text to the zone stamp as a workaround.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Mats_Knutsson
Mentor
Hi Erwin,
The room drawing consists of interior elevations. I'll try modifying the elevation marker.
/Mats
AC 25 SWE Full
