EDIT: This was not an issue to begin with - after re-checking the sections I realized that the problematic one was actually a duplicate of one of the other two; once I corrected the source to point to the correct section, all links work as expected. My bad. I am leaving my original post though, in case it helps someone else who stumbles the same way.
ORIGINAL POST BELOW:
I've got 3 sections in plan view. All 3 sections are placed in a layout, together with the plan view. Two of them work fine and are linked in the BIMx file I publish. The third one doesn't. You can see the section marker in plan, and you can see the section drawing on the layout. But it isn't linked, so there's no functionality with that one within BIMx.
All 3 sections are setup in exactly the same manner.
Any tips? Thanks.
Archicad 29.0.2 (3200) INT; macOS Sonoma
