Solid Element Operations and Renovation Filter
I have a simple terrain set to "Existing" and i have a slab set to "New" that sits on top and penetrates the terrain a bit. I subtract the slab from the terrain to make some sort of dig, but when go back and forth between Existing and New renovation filter the terrain has that solid operation applied on both states.
(the way to go around this is to split the terrain into parts, the ones that stay and the ones that are going to be demolished, which is generally a pain and a lot of work)
Is there a way for solid operations to be applied or not depending on the renovation filter?
5 REPLIES 5
Sorry, not possible to do.
So what method would you use in order to the same thing? and be able to have a correct demolition plan (digging plan)
DGSketcher
Legend
I haven't tried this but have you looked at PBC and Building Material strength values. This is different to SEO as in theory the stronger material e.g. your excavation profile should displace the ground when displayed. I recall doing something similar in the past. Sometimes it works but other times you have to play with the display order in the view.
This is a similar problem to adding an insulating skin to a wall for a renovation.
The entire wall need to be set as 'existing' or 'to be demolished' and then a 'new' wall added that includes the extra skin.
When viewing the new wall you hide the existing or to be demolished
So in your case you would have an 'existing' mesh with no SEO and then duplicate this as a 'new' mesh with the SEO.
When viewing the existing you hide the new, and when viewing the new you hide the existing.
the thing is that i need a demolition plan, so a floor plan and some sections that show, highlighted in red, slabs or terrain that has to go.
