2019-12-10 11:25 AM - last edited on 2023-05-19 03:31 PM by Gordana Radonic
2019-12-10 04:00 PM
2019-12-10 04:56 PM
2019-12-10 06:45 PM
2019-12-11 02:18 AM
papsphilip wrote:
So what method would you use in order to the same thing? and be able to have a correct demolition plan (digging plan)
2019-12-11 09:04 AM
DGSketcher wrote:the thing is that i need a demolition plan, so a floor plan and some sections that show, highlighted in red, slabs or terrain that has to go.
I haven't tried this but have you looked at PBC and Building Material strength values. This is different to SEO as in theory the stronger material e.g. your excavation profile should displace the ground when displayed. I recall doing something similar in the past. Sometimes it works but other times you have to play with the display order in the view.
