Some elements were deleted...
Some elements were deleted because of bad parameters. (4)
This message is driving me crazy. I draw a detail with the Detail tool, everything are lines, fills, and dimensions. I make a send/receive, then at plotmaker choose the import tool, select my plp and then my detail. When the import is done I only see the dimensions. I'm going back to AC, open my detail and is there! I check my layers, my layer combination and everything is fine. But when I make another send/receive the message pop up. I made a Sign Out/Sign In and the detail are empty, just with the dimensions. Then I open a new pln, draw the detail there and copy/paste to my plp, doesn't work. I create a new detail, start again my detail, it doesn't work. I'm stuck!! Somebody know why this is happen and how to fix it?
0 Replies 0
