Static VS associated dimensions
Tom Krowka
Am dimensioning to a zone on schematic site plan. Static dimension check box is off on the dimension dialogue box, so I would assume it would become associative.
Dimension to cornerns of the zone. However, when I adjust the zone size, dimension does not move and update with it. Does associative actually work with everything,or only certain elements.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
Link
I don't think dimensioning to zones is associative, and I think it is because of they way zones are updated.
The best way to know if a dimension is associated is when you place it. As you click to place dimensions nodes, you create temporary reference points. If these points show up as circles they are associative and as squares if they are not associative, or static.
Once the dimension is placed, you can hover over the markers of the dimension string and the associated element (if any) will be highlighted. Of course you'll need highlighting turned on in your Work Environment.
Link.
Tom Krowka
Oh well, another good idea (or so I thought) turns out not to be such a good idea.
Thomas@wkarchwk.com
www.walshkrowka.com
