‎2018-12-19
03:01 AM
‎2023-05-19
03:49 PM
Gordana Radonic
‎2018-12-19 04:49 AM
‎2019-03-26 06:09 AM
‎2019-03-26 08:27 AM
‎2019-03-27 12:41 AM
‎2019-03-27 03:41 AM
‎2019-03-27 11:58 PM
‎2019-03-28 02:21 AM
if bShowPlus then if name_place_int = 2 then ! On The line if AC_StoryElevation > 0 then txt_str_d = "+" + txt_str_d if abs(AC_StoryElevation) < EPS then txt_str_d = "±" + txt_str_d else if AC_StoryElevation > 0 then txt_str_u = "+" + txt_str_u if abs(AC_StoryElevation) < EPS then txt_str_u = "±" + txt_str_u endif endIf
If lvlRL = 1 then lock "bShowPlus" if name_place_int = 2 then ! On The line if AC_StoryElevation + GLOB_PROJECT_ALTITUDE > 0 then txt_str_d = "RL +" + txt_str_d if abs(AC_StoryElevation + GLOB_PROJECT_ALTITUDE) < EPS then txt_str_d = "RL ±" + txt_str_d if AC_StoryElevation + GLOB_PROJECT_ALTITUDE < 0 then txt_str_d = "RL " + txt_str_d else if AC_StoryElevation + GLOB_PROJECT_ALTITUDE > 0 then txt_str_u = "RL +" + txt_str_u if abs(AC_StoryElevation + GLOB_PROJECT_ALTITUDE) < EPS then txt_str_u = "RL ±" + txt_str_u if AC_StoryElevation + GLOB_PROJECT_ALTITUDE < 0 then txt_str_u = "RL " + txt_str_u endif else if bShowPlus then if name_place_int = 2 then ! On The line if AC_StoryElevation > 0 then txt_str_d = "+" + txt_str_d if abs(AC_StoryElevation) < EPS then txt_str_d = "±" + txt_str_d else if AC_StoryElevation > 0 then txt_str_u = "+" + txt_str_u if abs(AC_StoryElevation) < EPS then txt_str_u = "±" + txt_str_u endif endIf endif
‎2019-03-28 03:24 AM
‎2019-03-28 03:55 AM
