Story levels.
Can you insert a story level symbol without creating a new story? or do I need to create on from from scratch
3 Replies 3
Eduardo Rolon
If you need a new story symbol you should probably create the Story that it refers too.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
I want to show a deck or porch finish floor that is 6" lower than the main finish floor but I don't want to create a whole story level just for the porch
Eduardo Rolon
Then you can use a Level Dimension with Custom Text or buy
http://www.masterscript.nl/labels-and-markers/19-story-marker.html
or the one I use
http://www.masterscript.nl/home/33-elevation-dimension.html
AC29 US/INT -> AC08
