Story markers in decimal feet?
Is there a way to have story markers display the story levels in surveyor format (decimal feet to two decimal places) while the rest of the project uses feet-inches dimension format? If so how? If not, is there a workaround?
David Maudlin
Dorothy:
I think what you want (a screen shot would help) is to go to Project Preferences > Dimensions > Elevation Dimensions (5th button from left) and set as desired. Store As... this change, then assign that Dimension Setting to your View(s).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi David,
Thank you for your help. It was actually "level dimensions" (fourth button), but that did the trick.
