Survey Scale
When I merge a dwg survey into a worksheet, the dimensions change. As shown on the attached image showing 2'-6", the original dimension is 30'-0". Both the scales of the survey and the worksheet are 1' = 40'.
3 Replies 3
and what does AC measure on that particular dimension?
David Maudlin
Cheikh:
When Merging, check the Translator in the Merge DXF-DWG Model Space dialog box. In the Translator, look at Drawing Unit, my guess it is set to 1 Inch rather than 1 Foot, since 2'-6" x 12 = 30'-0".
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David,
Thanks so much. It worked.
Ilder,
AC was measuring 2'-6". Thanks.
