T.O.W. = <toAltvalue> with Label Tool?
Jeff Kogut
I'm looking to speed up labeling top of wall to sea level. We currently do this manually with the Level Dimension Tool, but frequently this takes up a lot of space in the wrong place.
I'd like to grab all my foundation walls and go to Document | Label Selected Elements instead using the label in the attached pic (on the right side). The Elevation Label 21 gets close, but only options are Project Origin and Current Story - no Sea Level option. Is there another way, or a 3rd party label anyone knows of?
AC19-23 | Win10 Pro | i7-8700K | Quadro P600 | 500gb 960 EVO M2 | Dual 28" 4k Samsung U28E590
I've got a custom Label that I can probably edit to accommodate what you want -- PM me with your email address and I'll see what I can do.
Jeff Kogut
Laura, thanks for the offer!
However we had an internal discussion about this last Friday and decided to use the following:
1. Crawlspace: Elevation Label 21, Custom Settings | Label Content | Reference Story > Project Origin
2. Basement: Elevation Label 21, Custom Settings | Label Content | Reference Story > Current Story
We're not fighting the program then. Crawlspace labels will have a negative value dimension from main floor/project origin and basements will be positive from top of basement slab.
There are definitely benefits to using OTB Objects (including Labels). That said, you should never let the software control your desired output.
For that reason, I tried using the Elevation Label when it was introduced, but due to the limitations you stated, have stuck to the Label I created years ago.
