4 weeks ago
Hi, its a way to create a TIDP scheme in archicad, with indexes could be the best way or is there another way?
Operating system used: Mac Intel-based Tahoe 26
Solved! Go to Solution.
3 weeks ago - last edited 3 weeks ago
Yes, that could be a Sheet Index generated with those custom Layout Scheme fields I talked about. Probably, the "Description" column of your screenshot shows that name of the Layout, and most or all other fields are custom Layout Scheme fields.
4 weeks ago
Are you talking about the Task Information Delivery Plan?
3 weeks ago
Yes Laszlo, i think it can be created with some scheme
3 weeks ago
Well, if you look at what a TIDP contains, like Name/Title, Description, Level of Information Need (LOIN), Format, Delivery Date/Milestone, Author/Responsible Party, Predecessors/Dependencies, Project Stage, etc. I don't see how you could do this automatically.
The best I can think of is to create new Fields in the Layout Info Scheme panel of the Book Settings Dialog, so all the above fields would be available for all Layouts. Then, you would have to fill out these pieces info for each Layout, and then you could generate a Sheet Index.
3 weeks ago
- last edited
3 weeks ago
by
yes, something like this, it seems to be created in some schedule from Archicad:
3 weeks ago
Thanks Laszlo
