SOLVED!
Terrace Door 25 Fill
Viktorhgo
Hi All,
Hopefully, somebody can help me with this Terrace Door 25, I can´t remove or change the uncut fill pen, in this case, color pink. I review all 2D Settings for the door, but nothing seems to work. Any tip would be very helpful.
Thanks!! Best Regards.
Screen Shot 2022-01-31 at 1.31.34 PM.pngScreen Shot 2022-01-31 at 1.31.13 PM.pngScreen Shot 2022-01-31 at 1.31.19 PM.png
1 ACCEPTED SOLUTION
Solution
Miha_M
I think there is a bug in the GDL script of this element. Some of the settings for the background fills don't work as they should. Maybe somebody with more GDL knowledge can look into this?
As a workaround solution you could change the pen nr. 19 color in your used pen set. I guess it is set to pink right now?
| Archicad 4.55 - 27
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
4 REPLIES 4
Solution
Miha_M
| Archicad 4.55 - 27
Rajesh Patil
Is this happening with all doors or only for Terrace Door? Have you tried to open the same file on some other computer?
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
Viktorhgo
Hi Rajesh only with this Door, No I haven´t try it, will do.  Thanks.
Hi Miha, that could work! thanks. I really don´t use the pen 19 a lot.
Thanks !!
