Text Model/paper size
Bling Keeta
I wonder why dimensions and text labels do not have model/paper size options.
And how do I change the scale of drawings from Project to View map and not having to change the scales of dimension and label accordingly?
Ben Ling
B.L.LING ARCHITECT INC.
Vancouver, BC, Canada
Mac Pro 3.5 GHz 6-Core Intel Xeon E5
AC 20
4 REPLIES 4
felcunha
You can't. Nevertheless you can always change the scale of your view when it's inserted in your sheet.
That's what I do for example when I want to print reduced copies of my print sets.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Bling Keeta
That seems a serious omission by Graphisoft. If they could do it for Text, why not dimension/label. It is a unnecessarily cumbersome procedure .
For example, I am now able to save a ¼" plan from Project to View Map and change the scale to 1". All text remains ok as it was set to Model Size, but I need to manually change the dimension text and label text from 8 to 24 Pt. Then isolate all dimensions at 1" scale to a different layer.
The other way is to work on all files at one single scale, and change it as required when in Layout.
Any other thoughts?
Ben Ling
AC 20
Aaron Bourgoin
Ben. ... and grid lines!
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.27 Mac
MacOS Tahoe 26.2
Any other thoughts?
My other thoughts are about wondering why you are trying to do this. In changing from 1/4" to 1" scale, are you actually WANTING to have huge dimensions? In what circumstance would this be appropriate? I guess I'm just not understanding this. Most people want 8 pt. dimension text to be 8 pt. high regardless of the scale you display it in the layout view.
Richard
AC26 (since AC6.0), Win10
