Text position of dimensions
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-11-21
03:06 AM
2023-05-19
03:47 PM
Gordana Radonic
2019-11-21
03:06 AM
It's a big trouble when you really don't know when they return the default position and which one was changed except where i found.
Anyone has ideas about this case? thank you.
Labels:
- Labels:
Dimension Tools
Text
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-21 09:48 AM
2019-11-21
09:48 AM
I am finding there is some kind of rebuild of dimensions happening which results in dimension points being dropped, mostly associated with curtain walls. Unfortunately it is unpredictable. Your reformatting may be part of the same process.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-23 03:11 AM
2019-11-23
03:11 AM
Hi DGSketcher,
Thanks for your words, did you have any solution to solve this?
I think is should be considered as a bug.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-23 10:50 AM
2019-11-23
10:50 AM
No new solution on my side. The problem with curtain wall nodes has already been reported. Your problem seems a bit more specific, you should report it to your support channel as a bug.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-25 04:02 PM
2019-11-25
04:02 PM
Nhan wrote:Hi Nhan,
I modified the default position of text (just like the right side of the pic) but sometime texts turn back to the default position of itself, anyone else have problem like this?
Thanks for reaching out to us here!
I find your issue very weird and by default, something that should not happen! By design, dimensions should not revert, especially those for the walls, unless specifically done so by the command: Document -> Annotation -> Revert All Dimension Texts to Automatic Position
Also, editing the walls or selecting a different wall type should not revert the dimensions.
On the top of my head, I can only think of this being on a Teamwork basis and someone else is reverting the dimensions.
Can you please verify if this is really the case?
If not, would you be so kind to provide me the file - via PM - so I may test this with my colleagues and investigate the cause of this issue?
I'm eagerly awaiting your response, and I wish you a great day ahead of you.
Kind regards,
Ghaleb
Ghaleb Khadra
BIM Expert
GRAPHISOFT
https://helpcenter.graphisoft.com
BIM Expert
GRAPHISOFT
