Texture issues on angled walls
Design3
Hi there,
I am having issues with my brick texture showing up on an angled wall. Is this a bug with the software or is there way to fix this?? Thanks
2 REPLIES 2
ryejuan
Have you check if there are any other elements interacting with the wall?
In the end what is your Objective?
ArchiCAD 9 onwards
DGSketcher
Legend
The image looks overexposed to me, have you considered turning down the light source values?
Does the problem occur with a different AC supplied surface?
It may have something to do with the individual surface settings if this is a custom texture?  Try comparing them with a similar but AC supplied surface.
