2022-08-16 11:00 PM
Hi there,
I am having issues with my brick texture showing up on an angled wall. Is this a bug with the software or is there way to fix this?? Thanks
2022-08-17 10:56 AM
Have you check if there are any other elements interacting with the wall?
2022-08-17 03:23 PM
The image looks overexposed to me, have you considered turning down the light source values?
Does the problem occur with a different AC supplied surface?
It may have something to do with the individual surface settings if this is a custom texture? Try comparing them with a similar but AC supplied surface.
