Thick Lines when printing layout.
I have tried to search but cant find any topic that helps me with my problem.
In my layout the lines on the wall panel and similar things look very good, thin and nice. But when i print it, (A1 layout) both in Sections and Stories the lines get thick. This looks very unprofessional.
I use AC10 and the same thing happened when i tried to print one of the sections in A4 on another printer.
Can anyone help me?
7 Replies 7
Thomas Holm
Check scale and what penset you're using on the layout.
Where do i find those settings?
Eduardo Rolon
Options->Element Attributes
and
for the drawing, select the drawing placed in the Layout and "Right Click", select "Drawing Settings" and look for the "Pen Settings" pop up.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
David Maudlin
Holmen:
Select the Drawing on the Layout, open its Settings, in the Properties pane is the Drawing Scale (as well as the Original Scale), and the Drawing's Pen Set.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Now i tried chancing the pen set but the same thing happens. I tried two different plotters, but it look exactly the same on both.
I took a picture with the "Sketch" tool and it came out with thin and nice lines.
Thomas Holm
Have you checked the Hairline option in Archicad's Print dialog?
i`m really ashamed, thank you thomas.
Now the drawings look good again.
