Trace reference wall windows obscured
KeesW
I am using an existing floor plan as a trace reference for a revised plan. The walls of the revised plan obscure the trace-reference wall windows so that I can't trace them onto the revised plan. I've tried making revised plan walls wireframe in the wall layer but it doesn't seem to work. Revised plan walls are composite types. Any suggestions?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
Have a play with the buttons at the bottom of the T & R pallet.
You can bring the T & R in front, add splitters so you can compare the two views and you can also make fills transparent.
Guru
What I usually do is use a GO to make all my Cut Fills transparent.
Ling.
