I would like to create a library of 2D details and tables I use consistently in projects usable over different versions of Archicad.
Is there a export format that would work as a repository, ideally allowing for drag and drop insertion when reused with minimal or no post formatting.
Also I wish to avoid the creation of duplicated Pens, Line Types, Layers and Attributes if at all possible.
I could save a library pln file and use copy paste but this seems like a problematic management solution when dealing with multiple users.
Mod files are version dependent so cannot be used in older versions (they also bloat the files size)
DWG files tend to breakup text objects when exploded and re-colour fills and pens (unless i am missing an export option setting) .
Operating system used: Windows 10
