Eric B
Transparent FIlls for Zones
I know this has been discussed in the past but I am trying to make the fill on zones semi transparent
I thought I could do this but creating a Graphic Override and change the fill pattern to 25% and the background pen to 0 - This all seems logical
However when I do it all of the foreground pens change to a single colour and they do not retain the zone colours. It is the only Graphic Override applied
I could of course done something really stupid as well
See the attached screenshots
Original ZonesOriginal ZonesGO settingsGO settingsAfter GO appliedAfter GO applied
Any help would be greatly appreciated
Cheers
Eric
AC6 till current
PC and Mac
2 Solutions
CosminF
Hi Eric,
To be honest I didn't really understand what are you trying to achieve.
Here are zones with no GO, with their cover fill at 25%, transparent background
Now if I wanted to override them with a red hue, I just override the fill foreground.
does this answer your question?
Edit: or do you want to override just the background? I tried that and strangely, it doesn't override only the background pen.
edit2: I have tried and the GO works on any type of a fill that does not use a transparent background. if that is used, the override won't work.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
You can override the cover fill in the zone settings, but this will be in all views.
You still have to set the foreground pen colour as well otherwise they will all be the same.
Using the Graphic Overrides allows you to have different looks in different views.
Go to post
5 Replies 5
CosminF
Hi Eric,
The % fill and zero background pen will give you a semi-transparent fill.
But I don't know of any way to keep the original zone colour.
As you have noticed, the foreground colour changes as well.
You can control it with the foreground pen, but all zones will be the same.
You could set up separate rules for each zone category, and match the foreground pen with the colour of that category.
Then in the override combination, you add each of the rules for each category.
I hope you don't have too many zone categories.
Eric B
Thanks guys
I have a few schedules set up for reporting different areas, perimeters and volumes of zones and the I was wanting to use the zones to draw over different parts of the floor plan (or in some instances the entire floor plan) but I still wanted to see the floor plans underneath similar to the image
Layered ZonesLayered Zones
While I understand the colour will not be exactly the same when you apply a % fill I was hoping a tint of the original colour assigned to the zone would remain eg: because you weren't changing the foreground colour it would remain as set for the zone and by making the background colour (0) and the fill type  a % it would at least make the zone semi transparent
Yes Barry .. I could just create a dozen GO for each zone but seems a little excessive. For now I will take the extra step of assigning the colour to the zone and the the cover fill to achieve the same outcome and not worry about GOs
Thanks for your help
Eric
AC6 till current
PC and Mac
_carlos
In previous versions of archicad it was possible to override only the background and the color of the category of the zone was the same (with transparency).
Since the new version of the zone tool it's not possible. You have to define the foreground color. It has no sense.
https://community.graphisoft.com/t5/Documentation/IS-THERE-A-WAY-TO-MAKE-ZONE-FILL-COLOUR-TRANSPAREN...
