Trying to exclude story marker and lines in elevation using Graphic Overrides
paulmckean
Trying to exclude story marker and lines in a Graphic Override rule in elevations. Can't figure out how to select those elements. I thought it was a label or elevation marker but that does not work.
Any ideas? Thanks a lot.
Paul
AC 21, Windows 10.
Archicad 20, windows.
1 REPLY 1
If you want to turn particular storey levels off in all sections/elevations, you can do this in the 'Storey Settings' dialogue.
If you want to turn of all storey markers of in a single section/elevation, you can do that in the 'Section/Elevation Settings' dialogue.
If you want to turn off one particular storey level in one particular section/elevation, I don't think you can do this (except for cover with white lines and fills).
As far as I know storey levels are not something you can control with Graphic Overrides.
