Unwanted lines and elements not showing up in layout book
I have a few problems with the Archicad layout:
1. Not all of my site analysis drawing copies over to the layout (I miss the winter and summer sun positions when pasting the drawing [ I have tried unlocking and changing layers but it doesn't solve anything. ] )
2. I get additional lines running through my site analysis drawing when posting it on a layout (as shown below in the image):
Thanks in advance
Are you trying to Copy-Paste stuff to the Layout?
That is not the proper working method.
What you should do is:
1. While in the Floor Plan Viewpoint, save a View.
2. Display the Layout, then drag-and-drop the saved View onto the Layout. A Drawing will be created on the Layout, and the saved View will be the source of that Drawing.
Alternately, you can just right-click in the Floor Plan Viewpoint, and select the "Save View and Place on Layout" command of the context menu, which will also do the above two steps.
Thank you that solved both problems
