Rick Thompson
User error or corrupt dimensioning?
I have one file that developed a situation where I can't dimension property. It is an issue as I modify plns all the time so I need a clean workable file. If I try to dimension a wall it only dimensions to exactly where I click.. not the core, or with proper witness lines. If I move a window/door the dimension will not follow. No association. I noticed the "Dimension only the Core of Walls and Slabs" is dimmed and can not be altered. I tried opening the pln under "repair" and it want do anything... "can't read file" is the message?????
Any suggestions short of attempting copying the entire file into a clean new pln and rebuild all the stuff I would have to ... ugggg.
Something has caused the dimming of the dimension core only, but I don't know what that might be?
thanks
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Rick Thompson
Never mind:)
The "Static Dimension" was checked as default ... All this time! Too bad I am my only employee and can't blame someone else:)
How in the hell did that happen????
Rick Thompson
Mac Sonoma AC 26
