Using Reno filter to show multiple design options?
Thanks to you how helped me to understand the Reno filters. LIKE IT!
so now that i have used this tool to show, demo, new, existing, and grayed out the parts that are not addressed in the sheet using the graphics over ride settings, i am wondering.
can i also use the Reno filters to show multiple design options.
for example.
everything will be gray, using over ride except for the new construction.
the new construction would be say, 3 bathroom options. the way i have it set is all options, on new con set, would be on and right on top of one another.
i tried setting up a new filter set, option 1. but i still only have 3 base filters, new demo and existing that i have to work with.
is this possible the way i am thinking? or do i need to just use layers or another tool set?
thanks
Bill
I don't think that using Renovation Filters will accomplish what you want, as the filter settings are limited to the 3 states - Existing, Demo, and New.
I find setting up Layer Combinations is the way to go.
Bill
Bill Szustak RA
Principal, Springboard Design
ArchiCAD 25, macOS Ventura 13.4.1
See:
http://archicad-talk.graphisoft.com/viewtopic.php?t=38499
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks Karl. You are always a big help. I like your idea too, nice work around.
it would be very helpful if future versions of AC had the the additional options 1, 2, 3, etc. in the layer sets.
Thanks again.
