Hi - wondering if anyone help me decipher what is going on and how to solve it. I would like a wall object to have the same grey fill line type as a morph object (wall panelling). In the screenshot, the wall object is on the left side (a screen actually that is shielding a spiral stair beyond); and the wall panelling on the right side. I began with a complex profile for the reveals of the panels on the right side, but after struggling to get the right fill there, I converted to morph and applied a GO to plywood fills on morphs. Problem is I cannot seem to replicate the same for the wall object (that is, make a GO rule change the wall surface fill to a lighter grey). On top of that, in the elevation view, I cannot affect anything about the left wall at all - as can be seen in the screenshot showing the wall settings dialogue window being open, but the "okay" button greyed out. The only thing one can do is to cancel out of the settings - you cannot change or affect them at all in the elevation. Very strange problem, as I am able to select other walls and objects in the elevation and use the settings to manipulate them (even other walls) - but not these walls. Feeling like I have tried just about everything to get the cover fill on the wall to match the millwork light grey plywood fill that I want - to no avail. Hence posting here to see if anyone can help me with this problem. Thanks in advance.
AC28 (Apple Silicon)
macOS Tahoe 26.5
MBP M3 Max (16-inch 2023)
