Vertical section in window/door schedules?
Sandramuller
I know you can add a plan section but I can't see on the information  I researched online how to add a vertical section?
And if can you have more then one if your window has for example a fixed light on one side and an openable sash on the other side?
Automatically - no you can't see vertical sections of doors/windows.
You could copy and paste from an actual section and add it to the annotation.
mija
I use 2d cross section preview for this
Archicad 26, build 3001
Montenegro
My apologies.
There is a 2D cross section preview as mija points out.
I don't think you can control where it cuts the section or which direction it looks.
Seems to be just slightly of centre looking towards the centre?
Barry
