View Settings/zoom
Hi everyone,
Issue that has lingered for a bit:
I have a saved view placed on a layout at a scale of 1:50. If I later need to change the scale of this particular view, say to 1:100, I go into the saved view and change scale of view to 1:100. Now, when I go back into the layout, the window that previously showed my drawing centered is blank and the drawing content is in some far off location. I've tried playing with the zooming options within the view settings with no luck. Any ideas how fix this?
The workaround has been to delete the previously placed view in the layout and replace it with the updated view at new scale, but this seems not the correct or fastest way to be working...
Thanks!
I think that, though not perfect the button 'fit frame to drawing' is a better workaround. You will then only have to place again the drawing on it's original place, or crop it again if it is a partial view…
