Viewmap error while trying to open
Fabian_MENDEZ
Hello there community
When Im trying to open a plan view from the viewmap, the computer does not respond and the file becomes unaccesible.
Is there any solution to this crash?
Operating system used: Windows 10
Hi @Fabian_MENDEZ,
- You can check the action center tab first, I guess you may find the reason there.
- Also try to right click on the view and check its settings you may find a custom setting for layer combo or any other place.
- You can ask for help from technical support, they can be faster to guide you in these special cases.
AC 28 INT 3110/WIN 11
Hi @Fabian_MENDEZ,
Thanks! I will try your recommendations!
Setup info provided by author
