License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
Viewmap error while trying to open
Fabian_MENDEZ
Hello there community
When Im trying to open a plan view from the viewmap, the computer does not respond and the file becomes unaccesible.
Is there any solution to this crash?
Operating system used: Windows 10
Hi @Fabian_MENDEZ,
- You can check the action center tab first, I guess you may find the reason there.
- Also try to right click on the view and check its settings you may find a custom setting for layer combo or any other place.
- You can ask for help from technical support, they can be faster to guide you in these special cases.
AC 27 INT 5060/WIN 11
Hi @Fabian_MENDEZ,
Thanks! I will try your recommendations!
Setup info provided by author
