ā2011-11-10
08:34 PM
ā2023-05-30
10:05 AM
Rubia Torres
ā2011-11-13 09:08 AM
sglazebrook wrote:Are you certain the view settings are as you think? Highlight the view in the view map and check it's settings (in the "Properties" section of the view map).
HOWEVER, when selecting the View from the View Map to work on the drawing, the scale set in the View does not control the scale of the View (window) - it is controlled by the previous scale.
sglazebrook wrote:Are you changing the scale in the active window (lower left corner) or are you changing the scale using the view's "settings? You have to change it in the "settings" if you want it to "stick".
For example: I select the 1/4" View and the independent drawing is at 1/4" scale for working, I then select the 1/2" View and the layers change to the 1/2" layer settings but it is still at 1/4" scale and I have to change it at the bottom of the window.
ā2011-11-14 05:45 PM
ā2011-11-15 04:47 AM
